Re: why does my H voltage regulator only last a couple ye...
Posted by pete 23 on June 22, 2009 at 20:01:30 from (173.87.14.132):
In Reply to: why does my H voltage regulator only last a couple years? posted by Dann G on June 22, 2009 at 07:57:18:
My current draw test would be on the bench with normal battery voltage of 6 to 6.3 volts. Will add, I ran into a new 706 that would clean out the regulator in just a very few hours. More indepth testing revealed the field windings were
for a 6 volt generator, replacing them with proper windings solved problem.
