Posted by Janicholson on June 22, 2009 at 20:18:30 from (66.173.50.19):
In Reply to: electrical problem posted by Farmall Bob on June 22, 2009 at 19:38:12:
The big terminal with 10gauge wire should go to the amp meter. It connects to the side not connected to the battery. The # 2 terminal Connects to the big terminal with a spade connector, and a ring connector (very short wire) The #1 terminal connects to one side (Terminal)of an idiot light It needs to be a parking light bulb, not LED. The other side of the (terminal) lamp goes to the ignition switch terminal that goes to the ignition resistor, or coil (which ever). No part of the lamp is grounded. The light bulb can be replaced with a 3 amp 150piv diode from Radio Shack. The band (painted) end of the diode goes toward the alternator. Good luck, JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
