Re: M Stuck Valves
Posted by rustred on June 22, 2009 at 21:37:17 from (72.172.100.113):
In Reply to: M Stuck Valves posted by RickAshman on June 22, 2009 at 09:19:53:
ya, by the time you guys argue about wd40 or atf i would have the head pulled off valves removed and freed up AND the RUST CLEANED OUT of the valve guides and then lubed up and back together before you get done your patch job.just what do you think that rust left in the guides does.and also you can visually see how the valves and seats are, incase a valve job is due.i guess real mechanics know right from wrong.
Today's Featured Article - Buying your first tractor: Choosing the right one - by Chris Pratt. They cost less than the tax on a new tractor (at least where we live). They have the weight to do the job. They are simple and understandable. They even have a history and can be restored to become a major source of pride and enjoyment. But how do you know what to buy and how do you make the right purchase? There is a surprising number of machines available in every shape and size imaginable. Like most things in life, your needs have a lot to do with wh ... [Read Article]
