> A clamping diode or varistor across the contacts > makes sense too.
A varistor in parallel with the contacts would help. A diode would not (besides, at the time those machines were designed cheap high-current semiconductor diodes were not available).
> FWIW I recall the VR's on a couple 60's era, > Mack and Reo farm dumps where I wrenched > sometimes as a teenager. The trucks had BIG 80 > - 100 amp generators (this is pre-alternator > days...). The VR's had both capacitors and what > looked like diodes or resistors across both the > voltage and current regulator contacts inside > the VR box.
They most likely would have had a resistor and capacitor in series across the contacts. The values would have been chosen for a satisfactory compromise between limiting the voltage across the contacts and critically damping the RLC network.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
