Re: Farmall H: Engine Stuck
Posted by mkirsch on June 23, 2009 at 08:59:09 from (67.240.251.254):
In Reply to: Farmall H: Engine Stuck posted by RB in PA on June 21, 2009 at 14:39:00:
Could be any of 100 things wrong here.
It would help to know...
A. Did this happen while you were running the tractor?
B. Did this happen overnight or after a few days?
C. Has the tractor been sitting a long time?
If A, then something is broken. Gonna have to take it apart.
If C, then it may just be a ridge of rust in one of the cylinders. Pour some automatic transmission fluid down each cylinder. Jack up a wheel, put the tractor in 5th, and roll the wheel back and forth.
In the case of B, then it gets complicated. I would at least pull the valve cover to make sure all the valves are in place. If one dropped, then that would stop the engine from turning over.
