> We must be thinking of two different things > here. I don't see how opening the contacts > wouldn't interupt current through the field > coils.
The diode is in parallel with the field coil and reverse-biased when the contacts are closed. It is the nature of inductors to resist sudden changes in current (v=Ldi/dt). When the contacts open in the absence of a diode or snubber the current continues to flow (though decaying rapidly). It quickly charges the stray capacitance across the contacts to a high enough voltage to arc over. The diode shorts out this voltage by allowing the current to flow through it. The current then decays at a rate determined by the RL time constant of the inductance and resistance of the coil. A resistor in series with the diode will make it decay faster at the price of higher voltage across the contacts.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
