Farmall 706 injection pump / engine speed adjustment
Posted by Doug Hubbard on June 23, 2009 at 10:50:53 from (64.16.131.2):
I have a 706 with the rossa master injection pump.
The tractor starts easily and seems to run fine;
however, I can not adjust the engine speed, it
stays at the low idle speed.
The linkage to the pump seems to be working
correctly and I am able to kill the engine fine.
Any ideas?
Thanks, Doug
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
