Re: Farmall 300 LP Refuel Question
Posted by CoopertownBob on June 23, 2009 at 12:26:15 from (74.51.5.75):
In Reply to: Farmall 300 LP Refuel Question posted by old school on June 22, 2009 at 13:29:03:
Just added a hose/regulator/preventer to my backyard tank and fuel from it. Cost a bit to set up, but in the long run, is the least expensive way around here. I use a vacuum pump to purge the tank on the tractor first. I just pump it down like you would an A/C system then fill her up. Fills just fine, with little loss. I came up with this idea AFTER I lost nearly as much LPG as went into the tractor the first time I filled it this way.
You might try something similar using a portable 40 lbs bottle like forklifts use. That way, you can transport fuel back and forth, without having to haul the tractor to the filling station first. A better way, however, would be to call a local propane dealer who specializes in home delivery and see if he can fill you up on his way to another customer near you. If you wind up using enough, he might make special trips just for you. I've had the best luck using out of county dealers this way. They are always looking to make inroads into other dealer's territories.
