Re: Best way to remove the IH 2050A Loader from my 574?
Posted by JimB2 on June 23, 2009 at 14:48:18 from (99.240.236.11):
In Reply to: Best way to remove the IH 2050A Loader from my 574? posted by jason k on June 23, 2009 at 09:42:23:
Hi Jason, 574 has open center hydraulic system. Re your loader connections, there were two methods of connecting a loader on a 574.
1)The cheap method by connecting loader to the outlets of remote valves. If your loader is connected in this method all you have to do is to disconnect the loader hydraulic hoses.
2)The most common method is to hava a set of hydraulic control valves tapped into the hydraulic retun line by the right hand side of the seat from the outlet of the remote control valves to the input of the draft control under the seat. If this is how your loader is connected then you must connect the input hydraulic hose to the output hose.
Removing the loader, drive under a big tree and suspend the loader arms from the tree limb and back out of the arms then remove the loader harness one side at a time.
JimB
