Re: why does my H voltage regulator only last a couple ye...
Posted by Dann G on June 24, 2009 at 05:28:14 from (68.188.198.251):
In Reply to: Re: why does my H voltage regulator only last a couple ye... posted by gene bender on June 23, 2009 at 03:25:05:
the number on the gen is 1100501 1A29. The voltage regulator is marked 6v pos ground.
