Re: Super A carb rebuild questions (Carter)
Posted by Hugh MacKay on June 24, 2009 at 06:09:05 from (209.226.247.119):
In Reply to: Super A carb rebuild questions (Carter) posted by Fred Miller on June 24, 2009 at 04:56:22:
Fred: Personally I've given up on Carter carbs for Super A tractors. IH used about 5 different Carter carbs during Super A production and now the industry are trying to service them with two different kits. I've had both kits home and neither one uses the same gasket between the two halves as in my carb. It's been 20 years since my Super A didn't leak when shut off. Now, I blame that leak on the damn plastic tip on needle valve.
Zenith on the other hand do have kits for all their carbs. What's more I bought the kit for my 130 at CaseIH, and lo and behold a steel tipped needle valve. What a pleasure not having to shut gas off when I stop the tractor.
I think there is another problem with carb kits, in the past partsmen with a cavalier attitude have sold kits that were close, now folks are trying to match up based on wrong kit. I'm sure that is what's wrong in my own case, and it was me they sold the wrong kit to 20 years ago.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
