Re: Super A carb rebuild questions (Carter)
Posted by panningbros on June 24, 2009 at 08:00:14 from (66.82.9.61):
In Reply to: Super A carb rebuild questions (Carter) posted by Fred Miller on June 24, 2009 at 04:56:22:
The quality of carb kits are getting worse. Even with a new needle & seat its tough to get them to stop from dripping. It seems to me the hole in the seat used to be tapered a little. Now there is just a hole drilled in. We used Tisco kits for years, but I'm about fed up with them. Poor instructions and very few parts in kit. The gaskets are usually shrunk. Those die cast bowls are a pain. Usually warped some and tough to get screws and jets out. Allis used the same kind of setup for awhile. I suppose the companies just bought from whover was cheaper that year.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
