Re: why does my H voltage regulator only last a couple ye...
Posted by pete 23 on June 24, 2009 at 10:46:40 from (173.87.14.132):
In Reply to: why does my H voltage regulator only last a couple years? posted by Dann G on June 22, 2009 at 07:57:18:
Ok, another question here. Why doesn't some co. offer a solid state regulator for these oldler model tractors. Sounds like a simple enough unit to build . I know , not enough demand to make it profitable. Deere uses a simple diode in place of a mechanical point type cut out relay on some of their old beaters. Also, the vibrating point mechanical voltage regulator has to make and break many times a second so easy to see why if points don't make good contact each and every closing the voltage will be fluctuating. They tell me the zenor diode used in solid state regulators can interup current flow up to 7000 times a second. Don't know the guy who was sitting their counting this.
