Re: Fel Pro gaskets from NAPA
Posted by Andy Martin on June 24, 2009 at 12:35:23 from (199.197.2.142):
In Reply to: Re: Fel Pro gaskets from NAPA posted by Tom 43 on June 24, 2009 at 11:55:52:
I guess some folks just can keep a tractor running easier than others. We never boiled the F-12 over and I don't recall ever stalling it either. Light tractors for light work and heavy tractors for heavy work.
Maybe your number 8 is the key, your neighbor was ridiculing you.
Around here the Fordson made some tremendous winch tractors. There are many sitting around with a 3 ft winch drum on the front and either flat belt or open gear drive to power the winch which was almost as big as the tractor. They were used in the oil field on fixed derricks. Basically a self propelled winch rather than a tractor with a winch.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
