Re: THF Revealation: Eating Some Crow... Gag, Choke
Posted by Jim Becker on June 24, 2009 at 13:36:14 from (173.57.160.166):
In Reply to: THF Revealation: Eating Some Crow... Gag, Choke posted by Jim Allen on June 24, 2009 at 11:54:07:
A lot of sources for hydraulic oil have 2 grades of oil. One is usually labeled "hydraulic oil" with very few if any other claims. The second one is usually more expensive and labeled as compatible with HY-Tran and other higher grade oils. I believe that TSC usually has 2 grades like this. Do you know which of the 2 oils you tested?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
