Re: 1066 pto slips
Posted by Mazemeister on June 24, 2009 at 19:32:00 from (24.188.81.230):
In Reply to: 1066 pto slips posted by ih carl66 on June 24, 2009 at 19:23:03:
the pto has its own hyd system, independent of the rest of the tractor. lock-up pressure is adjusted by turning the nut on the top of the control valve (where the over-center linkage connects). not sure about 1066, but 986 book calls for something like 240 psi i think. you check pressure by removing the plug on the left side and screw in a gauge.
if it's already slipped much, your pto clutch pack is probably toast. that means time to pull the pto unit and rebuild. there's a kit from CIH with clutch pack, o rings, etc. the I&T book explains pretty well how to do it.
