Re: new farmalls 1947-1954 ??
Posted by Fawteen on June 25, 2009 at 01:21:01 from (72.95.106.42):
In Reply to: new farmalls 1947-1954 ?? posted by adaada on June 24, 2009 at 23:09:55:
That would be a "Letter Series" Farmall. For 1000 acres, most likely an M or Super M, which was the biggest offered at the time.
In descending order of size/horsepower, other possibilities are H, C, B, A or Cub. The H, C and A were also available as Supers. To the casual observer they look pretty much the same as a regular. M's and H's can be hard to tell apart at a glance to an uninformed viewer as well, but the H is noticeably smaller when sitting next to an M.
Less likely but also possible are the W6 and W4 which are "standard tread" versions of the M and H respectively. Technically, they're not Farmalls, they're Internationals, but again, the inexperienced observer won't know that. A red tractor is a "Farmall"...
With a clear picture and a closeup, you can see the different decals for the Super series, near the front of the tractor on the hood.
