Re: Super A carb rebuild questions (Carter)
Posted by tractorsam on June 25, 2009 at 06:30:55 from (142.68.43.114):
In Reply to: Super A carb rebuild questions (Carter) posted by Fred Miller on June 24, 2009 at 04:56:22:
Something to try with regards to the new style rubber (or whatever it is) tipped needles. I've found that if you install the needle in the seat and tap it a few times (it seems you need to be fairly vigorous about this, at least in comparison to its size) it will seal properly. Before doing this the carbs I rebuilt always leaked, since I started doing this I have yet to have one leak. Hope this helps, Sam
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
