Posted by Ernie Loganbill on June 25, 2009 at 08:10:02 from (4.245.7.198):
I recently acquired an old style radiator miss installed on an old tractor (Cletrac). It is a very heavy radiator with a cast iron tank (top and bottom) with cast iron sides. It has a hole thru the top tank (on the left side of center from the drivers seat) that appears to be for a steering shaft. On closer inspection I found the old IHC in a circle logo cast in the side supports and a part number "2990-DA" also. Can anyone tell me what that radiator might fit and would anyone be needing such a radiator? It appears to be in excellent shape. Thank you for your time and help.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
