Square headed bolts for wheels on Super A
Posted by marvintj on June 25, 2009 at 09:32:35 from (134.134.139.73):
The square headed bolts that fit into the wheel rims of the Super A have broken or are rusted very bad and need replacing. Can squared headed bolts be found anymore and if so where? Are they just a grade 5 bolt? What to use to replace them to bolt the rim to the wheel plate?
