Re: Super C transmission noise
Posted by Hendrik on June 25, 2009 at 10:51:14 from (84.85.78.15):
In Reply to: Super C transmission noise posted by Mike plainview on June 25, 2009 at 10:11:15:
Mike. I would not run the tractor any longer before knowing what is wrong. Probably either a bearing or a gear has failed. Further use might cause far greater damage to gears, shafts or castings. As a first step, pull the transmission cover and peek inside. Put it in gear, keep the clutch down and rock a rear wheel back and forward while peeking inside.
I don't know whether one can see the bull gears and the differential after having removed the transmission cover; for this you may have to pull the PTO assembly. Hope SC experts chime in.
HTH, Hendrik
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
