Re: Farmall H not starting
Posted by Wayne in MN on June 25, 2009 at 12:24:09 from (66.228.242.147):
In Reply to: Farmall H not starting posted by Timothy S. Eagan on June 25, 2009 at 07:41:13:
Did you put the ignition power supply wire ton the starter cable terminal instead of the battery cable terminal when replacing the switch?
Then the distributor only has electric power when holding the starter switch down.
If your lights only work when the starter is cranking that confirms the incorrect placement of the wire.
