Before digging into the transmission, take both the brake assemblies off & see if the noise goes away. Our 450 had the identical symptoms that you describe on your SC. We figured an axle bearing---turned out to be one of the small springs that retract the brake actuating pack had rusted one hook off & had fallen down where it intermittently got wedged between the brake casting & the rotating member. Worth a look--easier than going inside & then having to pull the brake anaways.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
