Re: Super C transmission noise
Posted by Brownie 450 on June 25, 2009 at 17:22:45 from (216.51.158.253):
In Reply to: Super C transmission noise posted by Mike plainview on June 25, 2009 at 10:11:15:
Take pedal return springs off of pedals. There is a bolt through a heavy spring that enters the brake assembly. I forget if it takes a 9/16 or a 5/8 wrench--remove the bolt keeping the spring & bolt in order. Forgot--there should be a jam-nut on the threaded bolt--loosen it to remove bolt.
Should be 5 bolts around circumference of brake housing--remove these. Pull straight out on the brake assembly to remove it. Lay the assembly out on a cardboard & make a mental note of how the discs And actuating plates are arranged in the housing.
Check actuating plate return springs[should be 3 of them]. If there are only 1 or 2 springs, you will probably find the remains of them somewhere in the brake casing. As long as you have the brakes out, clean everything up before replacement. Check in with what you find.
