Re: Farmall H not starting
Posted by El Toro on June 25, 2009 at 17:53:59 from (205.188.116.73):
In Reply to: Farmall H not starting posted by Timothy S. Eagan on June 25, 2009 at 07:41:13:
If you have a ballast resistor between the ignition switch and the coil it could the culprit.
Run a separate wire from the battery to the coil
then see if it will start & run. Hal
