Thank you everyone for you input. We did get it apart this evening and we are cleaning it up. It turns out that my problem geting the axles out was that they were binding up. I had already removed all of the bolts between the axle housing and the transmission. All of the weight of the axle housing was resting on the axles. Once we lifted the axle housing a bit, everything came apart nicely.
Also, thanks to those of you who pointed out that I needed to remove the top castle nut on each side of the ring gear. I suspect I would have torn that little plate to bits if you folks had not made me aware of this.
I'm sure I will be back with more questions. It's now time to clean everything up and start putting it back together.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
