Posted by pete 23 on June 25, 2009 at 20:50:59 from (173.87.14.132):
In Reply to: 350 hydraulics posted by Bob 02 Martin on June 25, 2009 at 19:17:02:
The o-rings only keep it from leaking to the outside and do not hold the load up. Fit of spool to body does that. Your spool is worn, add a single acting check valve to solve your problem. If you are using a double acting cyl it may be leaking internally causing pressure to equalize on both sides of cyl and in effect the displacement of the piston rod is holding the load and pressures get much higher and even a good valve may not hold the load up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
