The main hyd, pump and the power steering pump are piggy-back togather and share the same filter and oil intake from the transmission. on the left side of the tractor ahead of the clutch and the trans. check plug you see a big steel line that becomes a rubber hose that goes to the bottom of the steeering console and two smaller steel lines that follow the left frame forward to the steering gear pump. The pumps are in the housing where these lines orignate. The trans. holds about 15 gals. of hy-tran but the hyd. pump only uses the top 5 gal(+/-) so when the hyd. pump is low on oil you should have about 10 gal. left in the trans./rearend. Hope this information helps. Armand
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
