Re: H hydraulic problems
Posted by Janicholson on June 26, 2009 at 09:16:59 from (199.17.6.60):
In Reply to: H hydraulic problems posted by J.Bruns on June 25, 2009 at 23:35:24:
The answer depends on the type of system your tractor has. It is eather a belly pump (Clutch must be engaged to lift) or a live pump (Clutch can be pushed in and it still lifts) explaining could cause issues if the load is still up. Is there a rod on the right side going to a valve? Let us know. JimN
