Re: F 20 no spark
Posted by Andy Motteberg on June 26, 2009 at 12:53:03 from (4.143.217.35):
In Reply to: F 20 no spark posted by JiminIowa on June 25, 2009 at 22:10:12:
Clean up the points. Do you have the advance cover on the mag adjusted to where the mag is NOT grounded? Put in a new coil and condenser if it still has no spark. Still nothing, try the coil. If thats fine, you may need to have the horse shoe magnet recharged.
