Re: MTA hydraulic pressure
Posted by Janicholson on June 26, 2009 at 16:40:27 from (66.173.50.64):
In Reply to: MTA hydraulic pressure posted by Agco Avenger on June 26, 2009 at 16:27:32:
Your setup seems OK, they made 1200psi, that is not the same league as today's high pressure systems. If it is not up to that pressure, it is not likely the relief it is likely the pump. Pumps are really not rebuildable if the gears have touched the case.
End play can be tuned, but few shops do it.
New pumps are in the 600 to 750 category. Put a pressure gauge on it to see what is happening. JimN
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
