Re: through out bearing ??
Posted by Bob on June 26, 2009 at 17:37:39 from (69.178.228.68):
In Reply to: through out bearing ?? posted by Kevin L. Rayman on June 26, 2009 at 13:43:40:
Part # of the complete assembly is 117244C1. GOOGLE brings up sources as low as $158.00.
It would be interesting to see the actual bearing... does it come off of the carrier, or is it one piece? Any bearing manufacturer's name or part number on it?
If you can post any more info I have a couple of catalogs with photos and dimensions of TO bearings to see if it would match up with anything "off the shelf".
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
