Posted by Hand Clutch on June 26, 2009 at 18:56:23 from (98.192.176.157):
In Reply to: 350U LP posted by Zog on June 26, 2009 at 16:17:15:
You can make the diaphram. Find a industrial rubber buiness in your area and macth up the material. Punch the holes and your done. Getting the needle attached in the center is a little tricky, but not to bad. I have a 350 utility on L.P. You can also go to the MM disscusion board here and they have numorus places for help. L.P. and Molines go hand in hand!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
