Re: MTA hydraulic pressure
Posted by TJFMichigan on June 27, 2009 at 09:07:07 from (65.23.89.102):
In Reply to: MTA hydraulic pressure posted by Agco Avenger on June 26, 2009 at 16:27:32:
The answer to your question about a pressure relief valve in the square tank (reservior) is yes. You have to remove the it from the tractor and remove the access cover. Place a few small shims (washers) under the spring and this will increase the pressure. Check your pressure before and after so you know how much you raised. Suggest you don't over do it - just enough to operate your equipment. Tom
