Posted by puller1 on June 27, 2009 at 12:55:04 from (71.171.1.74):
In Reply to: IH 350 wheel bearing posted by Bob 02 Martin on June 27, 2009 at 12:36:37:
the outside bearing would most easily be removed by sliding out the pto & removing the large bolt at the bull gear. You can press out the axle by backing out the bolt against a block up against the opposite axle.You must first remove the 4 bolts on the cap holding the outside bearing in.The bearing will slide off the axle easier if you will use a wire brush on a grinder to remove any paint & rust from the axle.All this can be done without removing the tranny cover.Murphys law states that if you don't drain the gear oil you will drop the bolt that holds the bull gear & you will drop your wrench several times in it.It is not as bad a job as one would think. Hope this helps. Tim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
