Re: IH 350 wheel bearing
Posted by Farmall Bob09 on June 27, 2009 at 17:12:01 from (75.221.107.242):
In Reply to: IH 350 wheel bearing posted by Bob 02 Martin on June 27, 2009 at 12:36:37:
yes bob...after you take the cap off the outter axle bearing (4 bolts) and put a block inbetween the bull gear bolts...use a open end wrench and back the bolt off this will pull the axle outwards and eventually will come right out...I just did the bearings in mine...I found a local bearing house near me was cheaper than case ih, i paid 62.75 for the outter axle bearing (st-227) and 34.95 for the inner bearing (st-328) i dont have the numbers in front of me but case ih was between 75-80 dollars for the one bearing and i believe around 90 bucks for the other...good luck! Bob
