Re: ih 674 hyd problem
Posted by Redfan on June 27, 2009 at 17:46:43 from (203.29.168.156):
In Reply to: ih 674 hyd problem posted by joe 1971 on June 27, 2009 at 15:51:11:
The let down problem would most likely be leakage in spool valves and/or seals in lift cylinders.
But your other problems are certainly issues with the pump, which you will find down on the left hand side of the tractor. Try and get someone to do some pressure tests first if you can.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
