Re: IH 350 wheel bearing
Posted by mattofvinings on June 27, 2009 at 19:53:37 from (198.208.159.17):
In Reply to: IH 350 wheel bearing posted by Bob 02 Martin on June 27, 2009 at 12:36:37:
Couple of things...a bearing can be "loose" in one of two ways...first there can be wear issues between the inner and outer races, straightforward fix is to replace the bearing.
However, a more serious problem is that the inner or outer race has turned either in the housing or on the shaft (seen both over time on ball bearings used in other types of equipment)...which would then require some repairs to the case or the shaft itself. In other words, a new bearing would not fix that independently.
