Static inj timing is 1 degree BTDC on number one compression stroke. You remove two screw cover on side of pump, turn engine until mark comes around , might take two revolutions, and line up marks when pointer is at 1 degree on pulley. The automatic advance timing requires a window on that same location and need to know what you are expecting to happen. Some have speed advance, most have load advance. Totally different in expected results.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
