Re: w4 gear ratio
Posted by Wardner on June 28, 2009 at 12:00:28 from (4.154.241.29):
In Reply to: Re: w4 gear ratio posted by 45M-meathead on June 28, 2009 at 07:37:53:
I'd be looking at 460, 504, and 606 parts.
It's safe to say that the later gear stuff may need some modifications.
I mention the previous tractors because a SMTA can be slowed down with 560 gears. A SM or M is different from a SMTA so that is why I mentioned modifications. The same parallel can be drawn between a H and 460.
It would have been helpful if you had specified what gears. Or do you want to slow them all down?
If it is just first gear, get an IH low-low kit from the scrap yard.
