It depends on where the bolts go. For example, The clutch pressure plate and the clutch housing can be grade 5. Those are all 3/8 in. bolts, so torque would be 25-30 lbs. Bolts for motor mounts can be grade 5 or 8; either one is OK since the bolts are only holding the motor on the frame rails. You didn't mention cylinder head studs, but they would be grade 5 also, with maximum torque on cylinder head about 75 lbs. In general, I would use grade 5 on all replacement bolts. I torque everything when reassembling. Follow torque values according to bolt size. Hope this helps.
