Re: Super mta
Posted by CNKS on June 28, 2009 at 18:38:21 from (216.144.104.128):
In Reply to: Super mta posted by cazzhrdwd on June 28, 2009 at 17:54:53:
They could, but it would have to be from the engine back. The TA housing adds length and contains provision for the independent PTO. You can't just bolt a TA to a SM without all sorts of modification. You can usually tell by casting codes, also. The SMTA was built only in 1954, that is a Z code. Although the 400 can also have Z codes, anything later (A-up) can be considered a red flag.
