Re: 52 Super M coil
Posted by jack-Iowa on June 28, 2009 at 18:50:12 from (173.20.27.54):
In Reply to: 52 Super M coil posted by jack-Iowa on June 28, 2009 at 15:57:10:
thanks for the info. the SM was running and just did nothing but crank.
no fire attempt at all .
the coil looks pretty old.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
