walk around your tractor:look at steering linkage,spindles, clutch and brake pedals, clutch shaft, release brg by unbolting plate under clutch,water pump,rear axle brgs,steering box,this is pretty much a self explanitory thing to do. unless you dont know how to load a grease gun. i have had roughnecks work for me that could not do this.one even said this grease is red and the gun has blue grease is that ok?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
