Re: mw hand clutch on 53 super h
Posted by Dave S. on June 28, 2009 at 20:04:15 from (208.92.170.134):
In Reply to: mw hand clutch on 53 super h posted by jeff kirlik on June 28, 2009 at 13:43:53:
I started installing one in my H today. The clutch uses ball bearings that roll up a ramp and into a slight indention to keep it engaged. The H is suppose to have 30 lbs of force (push or pull, however you look at it)to engage the clutch. Mine has the instructions on the clutch cover plate. It is adjusted with the nut on the shaft under the cover plate
