Re: Losing spark.
Posted by Janicholson on June 28, 2009 at 20:42:02 from (66.173.50.67):
In Reply to: Re: Losing spark. posted by djone110 on June 28, 2009 at 15:48:11:
Almost every one on this board believes that the clear plastic filters are too restrictive on a gravity feed system. NAPA makes a filter for gravity feed. it is not as small. The restriction of a plastic filter seems at first to be irrelevant, but a fuel pump equipped vehicle has 4 to 8psi applied, whereas the gravity feed has only a 15 inch head of pressure. The small plastic filters also have a tough time with flow when even a little plugged up. I would either toss it, or use a gravity flow unit. Bad coils can come from the factory. A true 12v (no external resistor required) coil used with a resistor will not give good spark, (it thinks it is getting 4 volts or so.)
also check the side play in the distributor shaft. If you can see or feel play it is too much. JimN
