Posted by El Toro on June 29, 2009 at 04:02:49 from (205.188.116.73):
In Reply to: 52 Super M coil posted by jack-Iowa on June 28, 2009 at 15:57:10:
Clean those points with some 320 wet or dry until shiny. If they're pitted replace them. With your points open make sure your're getting battery voltage to the small terminals on your coil. Use a volt meter or test lite. As been mentioned NAPA 's IC14SB coil has a builtin ballast resistor for about $18.00. Remember if your battery is negative grounded your wire from the coil to the points needs to be on negative terminal of the coil. Replace the condenser first to see if it will start. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
