Hi Ron and Jim, to replace the leaking seal jack the tractor up and remove the wheel. Remove the hydraulic lift unit from the transmission and remove the stud in the end of the axle shaft. You then take out the 4 bolts holding the seal housing on the end of the axle then hit the back side of the wheel flange and the axleshaft will come out. You then pull the bearing of the shaft to get to the seal housing pull the housing of the shaft and replace the oil and felt seals. Hope you have been able to follow me. MJ
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
