Re: 756 gas starts then dies
Posted by Bob M on June 29, 2009 at 09:40:06 from (151.190.254.108):
In Reply to: Re: 756 gas starts then dies posted by John G. Hasler on June 29, 2009 at 09:31:59:
I agree. Either burned out ballast resistor, failed ignition switch or a break in the wiring somewhere in between.
I'd first look at the ballast resistor (temporarily short the two resistor terminals and see if the tractor will run...)
