Re: Farmall M PTO assy
Posted by pete 23 on June 29, 2009 at 10:47:50 from (173.87.14.132):
In Reply to: Farmall M PTO assy posted by Allan Kropelnicki on June 29, 2009 at 08:50:55:
You have to look at the lower transmission shaft from the rear, if it has the splined end on shaft you can put a compatable pto right in. Being a 48 model it would use the extended housing type, not old original flush mounted one.
